Sub Normal_Example()
' This example creates an circle and determines its Normal property.
' It then creates a vector and uses it to reset the Normal property.
Dim myCircle As AcadCircle
Dim ctrPt(0 To 2) As Double
ctrPt(0) = 5: ctrPt(1) = 3
'Add the arc to the .dwg
Set myCircle = ThisDrawing.ModelSpace.AddCircle(ctrPt, 5)
' Display the entity
myCircle.Update
ThisDrawing.Application.ZoomExtents
Dim vNormal As Variant
vNormal = myCircle.Normal
MsgBox "Circle's normal Vector:" & _
Chr(13) & "x = " & vNormal(0) & _
Chr(13) & "y = " & vNormal(1) & _
Chr(13) & "z = " & vNormal(2)
Dim vecNormal(0 To 2) As Double
vecNormal(0) = 0.5: vecNormal(1) = -0.8
myCircle.Normal = vecNormal
myCircle.Update
MsgBox "Circle's normal Vector is now:" & _
End Sub
