Sub ObliqueAngle_Example()
' This example creates text and adds it to the drawing using the
' AddText method. It then obtains and resets the ObliqueAngle property.
Dim sText As String: sText = "Test string for ObliqueAngle property"
Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9
Dim dHeight As Double: dHeight = 5
Dim textObj As AcadText
Set textObj = ThisDrawing.ModelSpace.AddText(sText, insPt, dHeight)
textObj.Update
ThisDrawing.Application.ZoomExtents
MsgBox "The ObliqueAngle is " & textObj.ObliqueAngle
'Change the value of the ObliqueAngle to 45 degrees (0.785 radians)
textObj.ObliqueAngle = 0.785
textObj.Update
MsgBox "The ObliqueAngle is set to " & textObj.ObliqueAngle
End Sub
