TextString property example
Private Sub
TextString_Example()
This example creates text and adds it to the drawing using
the
AddText method. It then returns the TextString in a message
box.
Dim icadDoc As
IntelliCAD.Document
Dim myText As String
Dim textObj As
IntelliCAD.Text
Dim insPt As
IntelliCAD.Point
Dim height As Double
Dim NewScaleFac As
Double
Set icadDoc =
ActiveDocument
Set insPt =
Library.CreatePoint(0, 9)
height = 5
myText = InputBox("Type some
text here:")
Add the Text object
Set textObj =
icadDoc.ModelSpace.AddText(myText, insPt, height)
textObj.Update
ThisDocument.ActiveViewport.ZoomExtents
MsgBox "The text you type is:
" & textObj.TextString
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
