Sub CenterPlot_Example()
' This example returns the CenterPlot property.
'display the centered state all layouts
MsgBox CenterPlotStatusToString(ThisDrawing.Layouts)
' Toggle centered state for Layout1
ThisDrawing.Layouts("Layout1").PlotType = acDisplay
ThisDrawing.Layouts("Layout1").CenterPlot = Not (ThisDrawing.Layouts("Layout1").CenterPlot)
ThisDrawing.Regen acAllViewports
End Sub
Private Function CenterPlotStatusToString(allLayouts As AcadLayouts) As String
Dim sBuf As String: sBuf = vbNullString
Dim thisLayout As AcadLayout
Dim sCenterStatus As String
For Each thisLayout In allLayouts
sCenterStatus = IIf(thisLayout.CenterPlot, " is ON.", " is OFF.")
sBuf = sBuf & "The .CenterPlot status for " & thisLayout.Name & sCenterStatus & vbCrLf
Next
CenterPlotStatusToString = sBuf
End Function
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
