GraphicsWinBackgrndColor property example
Sub GraphicsWinLayoutBackgrndColor_Example()
    ' This example returns the current setting of GraphicsWinLayoutBackgrndColor.
    Dim myPrefs As AcadPreferences
    Set myPrefs = ThisDrawing.Application.preferences
    Dim currLayoutBGColor As OLE_COLOR
    ' Retrieve the current GraphicsWinLayoutBackgrndColor value
    currLayoutBGColor = myPrefs.Display.GraphicsWinLayoutBackgrndColor
    MsgBox "The current value for GraphicsWinLayoutBackgrndColor is " & currLayoutBGColor
End Sub
