Sub HistoryLines_Example()
' This example returns the current setting of HistoryLines.
Dim myPrefs As AcadPreferences
Set myPrefs = ThisDrawing.Application.preferences
Dim iHistoryLines As Integer
' Retrieve the current GraphicsWinLayoutBackgrndColor value
iHistoryLines = myPrefs.Display.HistoryLines
MsgBox "The current value for HistoryLines is " & iHistoryLines
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
