Sub MaxAutoCADWindow_Example()
' This example returns the current setting of MaxAutoCADWindow.
' It then changes the value, and finally resets it it's original setting.
Dim myPrefs As AcadPreferences
Set myPrefs = ThisDrawing.Application.preferences
Dim bCurrMaximizedState As Boolean
'Get the current MaxAutoCADWindow state
bCurrMaximizedState = myPrefs.Display.MaxAutoCADWindow
MsgBox "The current value for MaxAutoCADWindow is " & bCurrMaximizedState
'Change the state of MaxAutoCADWindow
myPrefs.Display.MaxAutoCADWindow = Not (bCurrMaximizedState)
MsgBox "The new value for MaxAutoCADWindow is " & preferences.Display.MaxAutoCADWindow
'Reset MaxAutoCADWindow to its original state
myPrefs.Display.MaxAutoCADWindow = bCurrMaximizedState
MsgBox "The MaxAutoCADWindow value is reset to " & preferences.Display.MaxAutoCADWindow
End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
