Sub HyperLinks_Example()
' This example adds an Mtext to the model space and
' adds a new Hyperlink to its Hyperlinks collection.
Dim oMtext As AcadMText
Dim sTextString As String
Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9
sTextString = "\LSelect text, then right-click and use Hyperlink>Open"
Set oMtext = ThisDrawing.ModelSpace.AddMText(insPt, 18, sTextString)
oMtext.height = 1
oMtext.width = 18
oMtext.Update
ThisDrawing.Application.ZoomExtents
' Get reference to the Mtext Hyperlinks collection
Dim Hyperlinks As AcadHyperlinks
Dim Hyperlink As AcadHyperlink
Set Hyperlinks = oMtext.Hyperlinks
' Add a new Hyperlink complete with all properties
Set Hyperlink = Hyperlinks.Add("Bricsys")
Hyperlink.URL = "http://www.bricsys.com/en_INTL/bricscad/"
Hyperlink.URLDescription = "The Bricscad Site"
Hyperlink.URLNamedLocation = "Bricscad"
' create a list of existing Hyperlinks and their properties for this object
Dim sBuf As String
For Each Hyperlink In Hyperlinks
sBuf = sBuf & "____________________________________" & vbCrLf
sBuf = sBuf & "URL: " & Hyperlink.URL & vbCrLf
sBuf = sBuf & "URL Description: " & Hyperlink.URLDescription & vbCrLf
sBuf = sBuf & "URL Named Location: " & Hyperlink.URLNamedLocation & vbCrLf
Next
MsgBox "The Mtext object has " & Hyperlinks.count & " Hyperlink: " & vbCrLf & sBuf
End Sub
