Sub Area_Example()
' This example adds a circle to the drawing and returns it's Radius and Area.
' It the modifies the radius and returns modified values.
Dim cenPt(0 To 2) As Double: cenPt(0) = 4: cenPt(1) = 2: cenPt(2) = 0
Dim dRadius As Double: dRadius = 2.5
'Add the arc to the .dwg
Dim myCircle As AcadCircle
Set myCircle = ThisDrawing.ModelSpace.AddCircle(cenPt, dRadius)
' Display the entity
myCircle.Update
Dim dArea As Double:
dArea = myCircle.Area
dRadius = myCircle.radius
MsgBox "Area = " & dArea & Chr(13) & "dRadius = " & dRadius
' modify the radius
myCircle.radius = 5#
myCircle.Update
MsgBox "Area = " & myCircle.Area & _
Chr(13) & "Radius = " & myCircle.radius & _
Chr(13) & "Diameter = " & myCircle.Diameter
End Sub
