Returns the type of entity for a selected object. The property is returned as an integer value, as shown in the table below.
Syntax
Where:
integerVariable is a variable for storing the entity type value.
object is a valid entity object.
| Entity Types | Value |
Attribute |
4 |
AttributeDef |
5 |
BlockInsert |
6 |
Circle |
7 |
Dimension (3-pt Angular) |
8 |
Dimension (Aligned) |
9 |
Dimension (Angular) |
10 |
Dimension (Diametric) |
11 |
Dimension (Ordinate) |
12 |
Dimension (Radial) |
13 |
Dimension (Rotated) |
14 |
Hatch |
9 |
3dFace |
1 |
3dPoly |
2 |
Arc |
3 |
Ellipse |
15 |
ExternalReference |
16 |
Hatch |
17 |
Image |
18 |
InfiniteLine |
19 |
Leader |
20 |
Line |
21 |
LWPolyline |
22 |
Mtext |
23 |
PointEntity |
24 |
PolyfaceMesh |
27 |
PolygonMesh |
26 |
Polyline |
25 |
Pviewport |
28 |
Ray |
29 |
Solid |
30 |
Spline |
31 |
Text |
32 |
Tolerance |
33 |
Trace |
34 |
UnknownEntity |
0 |
Examples...
