Sub Linetype_Example() 'This example returns the Linetype property. Dim ents As Object Dim ent As Object Dim ct As Long Set ents = ThisDrawing.ModelSpace ct = ents.count Set ent = ents.Item(ct - 1) MsgBox "The Linetype property for the last entity is: " & ent.Linetype End Sub
