Sub Thickness_Example()
' This example adds an arc to the drawing. It then obtains
' the Thickness property and prompts the user to supply a new thickness.
Dim myArc As AcadArc
Dim cenPt(0 To 2) As Double: cenPt(0) = 4: cenPt(1) = 2
Set myArc = ThisDrawing.ModelSpace.AddArc(cenPt, 3, 1, 3)
myArc.Update
Dim dThickness As Double
dThickness = myArc.Thickness
MsgBox "Arc's thickness = " & dThickness
dThickness = InputBox("Enter new thickness for arc:")
myArc.Thickness = dThickness
End Sub
