Sub GetExtensionDictionary_Example()
' This example creates a Circle object in model space and
' adds a new Extension Dictionary to the Circle object
Dim EDictionary As AcadDictionary
Dim circleObj As AcadCircle
Dim centerPoint(0 To 2) As Double
Dim radius As Double
' Define the Circle object
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
radius = 5#
' Create the Circle object in model space
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
ThisDrawing.Application.ZoomAll
MsgBox "Circle object Extension Dictionary state before: " & circleObj.HasExtensionDictionary
' Create an Extension Dictionary for the new Circle
Set EDictionary = circleObj.GetExtensionDictionary
MsgBox "Circle object Extension Dictionary state after: " & circleObj.HasExtensionDictionary
End Sub
