You can change the magnification of your drawing at any time by
zooming. The cursor changes to a magnifying glass (
) when a Zoom tool is active.
Zoom out to reduce the magnification so you can see more of the
drawing, or zoom in to increase the magnification so you can see a
portion of the drawing in greater detail. Changing the
magnification of the drawing affects only the way the drawing is
displayed; it has no effect on the dimensions of the entities in
your drawing.
Do one of the following:
Type zoom in the command bar.
Type Z in the command bar.
The command bar reads: In/Out/All/Center/Extents/Left/Previous/Right/Window/<Scale (nX/nXP)>:
A prompt menu opens:
Type the zoom factor, followed by X. E.g. type 2x to magnify the display 2 times; typing 0.5x changes the display to half its original size.
In paper space viewports, type the zoom factor followed by XP to define the zoom factor relative to the viewport, thus defining the scale of the viewport content.
Pick two corners of a box on the existing view in order to enlarge that area to fill the display.
Keyboard |
Prompt Box |
I |
Zoom in |
Zooms in on the center of the window by a factor of 2 ( |
O |
Zoom out |
Zooms out from the center of the window by a factor of 0.5
A |
All |
Displays the whole drawing as far as its drawing limits or
drawing extents (whichever is the greater
of the two) ( |
C |
Center |
Pick the center of the next view, then specify the magnification
factor or the view height ( |
E |
Extents |
Displays all the entities in the drawing (referred to as
the drawing extents) ( |
L |
Left |
Pick the lower left corner of the next view, then specify the
magnification factor or the view height ( |
P |
Previous |
Restores the displayed view prior to the current one
R |
Right |
Pick the upper right corner of the next view, then specify the
W |
Window |
You are prompted to pick two corners of a box on the existing
view in order to enlarge that area to fill the display ( |
Click the Real-Time
Zoom tool button (
) in the View toolbar.
Type rtzoom in the command bar, then press Enter.
The command bar reads: >>ENTER, Right click or Esc to complete...
Press and hold the left mouse button.
Move the mouse forward to zoom in.
Move the mouse backward to zoom out.
To abort the Real-Time Zoom command, do one of the following:
Right click.
On the keyboard, press Enter, space bar or Esc.
