Creating diametrical and radial dimensions
Diametrical and radial dimensions annotate the radii and diameters of circles and circular arcs.
The Dimcenter tool creates center marks in the center point of circles and circular arcs.
To create a diametrical dimension
  1. Do one of the following
  2. Click the Diameter tool button () on Circles toolbar or the Circles flyout of the Dimensions toolbar.
  3. Choose Diameter in the Dimensions menu.
  4. Type dimdiameter in  the command bar, then press Enter.
The command bar reads: Select arc or circle
  1. Select the arc or circle you want to annotate.
    The diametrical dimension displays dynamically.
  2. Position the dimension line.
To create a radial dimension
  2. Click the Radius tool button () on Circles toolbar or the Circles flyout of the Dimensions toolbar.
  3. Choose Radius in the Dimensions menu.
  4. Type dimradius in  the command bar, then press Enter.
    The radial dimension displays dynamically.
Creating center marks or center lines
  2. Click the Center tool button () on Circles toolbar or the Circles flyout of the Dimensions toolbar.
  3. Choose Center in the Dimensions menu.
  4. Type dimcenters in  the command bar, then press Enter.
  1. Select the arc or circle.
    The center marks are created.
NOTE
The Center mark setting of the dimension style controls whether center marks or center lines are created.
The Center mark size settings of the dimension style controls the size of the center mark.
See also the DIMCEN settings variable in the Settings dialog.
