Do one of the following:
Click the Image
Transparency tool button () on the Images toolbar.
Choose Image Transparency in the Images menu.
Type transparency in the command bar, then press Enter.
The command bar reads: Select images.
Select the images you want to set the Transparency property of.
The command bar reads: Enter transparency mode [ON/OFF]<current
mode>:
Press Enter to accept the current mode.
Choose On in the context menu or type ON in the command bar, then press Enter to switch the Transparency property of the selected images on.
Choose Off in the context menu or type OFF in the command bar, then press Enter to switch the Transparency property of the selected images off.
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
