Works with Bricscad (Windows) Pro and Platinum Bricscad (Windows) Pro and Platinum
Adds or removes volume from a solid by moving a face or surface.
command bar: dmpushpull
menu bar: Model | Direct Modeling | Push/Pull
toolbar: Direct Modeling |
: dmpushpull
Select faces or closed 2D contours to push/pull: (select one or more faces on the same or different solids; press and hold the Ctrl key to select multiple faces. Press and hold the TAB key to select hidden geometry. Press Enter to stop selecting.)
The selected surfaces are edited dynamically. Click to define or type a value in the dynamic entry field. Press the TAB key to display an alternative dynamic entry field (e.g. absolute distance instead of relative distance).
Planar faces |
The faces are moved, thus adding or removing volume from the solid(s). The value of the movement vector displays in the dynamic entry field. |
Cylindrical and spherical faces |
Edits the radius. The current radius displays in the dynamic entry field. |
Toroidal faces |
Edits the tube radius of the torus. The current radius displays in the dynamic entry field. |
dmChamfer - creates an equal distance chamfer between adjacent faces sharing a sharp edge.
dmDelete - deletes faces and solids.
dmExtrude - creates a 3D solids by extruding closed 2D entities or regions.
dmFillet - creates a smooth fillet between adjacent faces sharing a sharp edge.
dmMove - moves the selected faces or edges of a solid using a vector.
dmRevolve - Creates 3D solids by revolution of closed 2D entities or regions about an axis.
dmRotate - rotates faces of a solid around an axis.
