Sub AddBox_Example() ' This example adds a box to the drawing using the AddBox method. Dim boxObj As Acad3DSolid Dim Pt1(0 To 2) As Double: Pt1(0) = 1: Pt1(1) = 1: Pt1(2) = 0 Set boxObj = ThisDrawing.ModelSpace.AddBox(Pt1, 3, 3, 4) boxObj.Update ThisDrawing.Application.ZoomExtents End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
