Adds a 3 Point Angular dimension object.
Syntax
Where:
AngleVertex is a Variant identifying the center of the circle or arc, or the common vertex between the two dimensioned lines;
FirstEndPoint is a Variant identifying the point through which the first extension line passes;
SecondEndPoint is a Variant identifying the point through which the second extension line passes;
TextLocation is a Variant identifying the location of the text.
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
