Adds an Aligned dimension object.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
ExtPoint1 is a Variant identifying the first endpoint of the extension line;
ExtPoint2 is a Variant identifying the second endpoint of the extension line;
TextLocation is a Point object identifying the location of the text.
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
