Sub addHatchExample() addHatchPreDefined addHatchUserDefined End Sub Private Sub addHatchUserDefined() ' This example creates an associative User defined hatch in model space. Dim hatchObj As AcadHatch Dim patternName As String Dim patternType As AcPatternType Dim bAssociativity As Boolean patternName = "_USER" patternType = acHatchPatternTypeUserDefined '0 bAssociativity = True Set hatchObj = ThisDrawing.ModelSpace.addHatch(patternType, patternName, bAssociativity) Dim outerLoop(0 To 0) As AcadEntity Dim center(0 To 2) As Double: center(0) = 10: center(1) = 5: center(2) = 0 Dim radius As Double: radius = 3 Set outerLoop(0) = ThisDrawing.ModelSpace.AddCircle(center, radius) hatchObj.AppendOuterLoop (outerLoop) hatchObj.Evaluate ThisDrawing.Regen True End Sub Private Sub addHatchPreDefined() ' This example creates an associative predefined hatch in model space. Dim hatchObj As AcadHatch Dim patternName As String Dim patternType As AcPatternType Dim bAssociativity As Boolean patternName = "ANSI31" patternType = acHatchPatternTypePreDefined '1 bAssociativity = True Set hatchObj = ThisDrawing.ModelSpace.addHatch(patternType, patternName, bAssociativity) Dim outerLoop(0 To 0) As AcadEntity Dim center(0 To 2) As Double: center(0) = 5: center(1) = 5: center(2) = 0 Dim radius As Double: radius = 3 Set outerLoop(0) = ThisDrawing.ModelSpace.AddCircle(center, radius) hatchObj.AppendOuterLoop (outerLoop) hatchObj.Evaluate ThisDrawing.Regen True End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
