Sub AddLineExample() ' This example creates a line and adds it to the drawing ' using the AddLine method. Dim myLine As AcadLine Dim Pt1(0 To 2) As Double Dim Pt2(0 To 2) As Double Pt1(0) = 4: Pt1(1) = 4: Pt1(2) = 0 Pt2(0) = 7: Pt2(1) = 1: Pt2(2) = 0 Set myLine = ThisDrawing.ModelSpace.AddLine(Pt1, Pt2) myLine.Update ThisDrawing.Application.ZoomExtents MsgBox "Line created from 4,4 to 7,1." End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
