Sub AddPointExample() 'This example adds a point entity to the drawing using the AddPoint method. Dim Pt1(0 To 2) As Double Dim myPtEnt As AcadPoint Pt1(0) = 4: Pt1(1) = 2 Set myPtEnt = ThisDrawing.ModelSpace.AddPoint(Pt1) myPtEnt.Update MsgBox "Point added at 4,2.", vbInformation, "AddPoint Example" End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
