AddTolerance method example
Sub AddTolerance_Example()
' This example creates a tolerance object in model space.
    Dim toleranceObj As AcadTolerance
    Dim sBuf As String
    Dim insPt(0 To 2) As Double
    Dim dirVect(0 To 2) As Double
    ' Define the tolerance object
    sBuf = "{Fgdt;i}%%v{Fgdt;n}55{Fgdt;s}%%v{Fgdt;n}22{Fgdt;m}%%v11{Fgdt;l}%%v%%v"
    insPt(0) = 10: insPt(1) = 10#: insPt(2) = 0#
    dirVect(0) = 1: dirVect(1) = 0: dirVect(2) = 0#
    ' Create the tolerance object in model space
    Set toleranceObj = ThisDrawing.ModelSpace.AddTolerance(sBuf, insPt, dirVect)
    toleranceObj.Update
    ThisDrawing.Application.ZoomExtents
End Sub
