Deletes a fit point from the spline.
Syntax
Where:
object is a AcadSpline object;
Index is a Long Integer variable (or value) identifying the position in which to delete the fit point.
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
