Returns the control point to the spline at the given index.
Syntax
Where:
object is a Bricscad Spline object;
Index is a Long integer variable (or value) specifying the position of the control point.
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
