Sub Example_SaveAs() ' The following example saves current drawing as "test.dwg" Call ThisDrawing.SaveAs("test.dwg", ac2007_dwg) End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
