ScaleEntity method
Scales the entity or members of a selection set by a given scale factor.
Syntax
object.ScaleEntity(BasePoint, ScaleFactor)
Where:
     object is a Bricscad entity;
     BasePoint is a Variant (three-element array of doubles) representing the point about which the entity will be scaled;
     ScaleFactor is a double-precision variable (or value) representing the factor by which to scale the entity or entities.
