Sets the visibility for a 3DFace edge at a given index.
Syntax
Where:
object is a Viewport or PViewport object;
Index is an Integer representing the index number of the face;
State is a Boolean variable specifying whether the visibility is on (True) or off (False).
Examples...
SetInvisibleEdge method example
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
