Writes out the given selection set as a new drawing file.
Syntax
Where:
FileName is a string variable representing the name of the file to be created.
SelectionSet is a selection set containing the blocks to be written.
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
