Class AcadAcCmColor
Member of BricscadDb
The AcCmColor object represents colors. You can use the AcCmColor object to set colors and perform other color-related operations on objects.
This object can hold an RGB value, an ACI number (an integer from 1 to 255), or a named color.
Methods | Properties |
SetColorBookColor | Blue |
SetNames | BookName |
SetRGB | ColorIndex |
ColorMethod | |
ColorName | |
EntityColor | |
Green | |
Red | |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
