Sub ActiveDocProp_Example() 'This example shows how to return the name of the active document. Dim activeDoc As AcadDocument Set activeDoc = ThisDrawing.Application.ActiveDocument MsgBox "The active document is: " & activeDoc.Name, vbInformation, "ActiveDocument Example " End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
