Sub ApplicationProp_Example() 'The following example demonstrates how to return the Application property. Dim myObject As AcadApplication Set myObject = ThisDrawing.Application MsgBox ("Application is: " & myObject.Name) End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
