Sets or returns if the entity is closed.
Syntax
Where:
BooleanVariable specifies whether the object is closed (True) or not (False).
Object is the entity a 3DPolyline, LightweightPolyline, Polyline, Spline for which you set or return the Closed property.
Examples...
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
