DisplaySilhouette property
Sets or returns whether the silhouette curves of solids are displayed. The value of this property is stored in the DISPSILH system variable.
Syntax
BooleanVariable = object.DisplaySilhouette
object.DisplaySilhouette = <Boolean>
where:
     BooleanVariable determines whether the curves are displayed (True) or not (False).
     object is the DocumentPrefernces object.
Examples ...
DisplaySilhouette property example
