Sub FullName_Example() ' This example uses the FullName property to find the full ' name of the current drawing, and of the application. Dim docName As String docName = ThisDrawing.FullName MsgBox "The full name of the current drawing is " & docName Dim appName As String appName = ThisDrawing.Application.FullName MsgBox "The full name of the current application is " & appName End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
