Returns the object immediately above the selected object in the object model hierarchy. For example, the Parent of an Arc object is Entities.
Syntax
Where:
objectVariable is a variable representing the Parent object.
object is any valid object.
Examples...
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
