The following example demonstrates how to return the Path property.
Sub Path_Example() Dim myPath As String myPath = ThisDrawing.Application.Path MsgBox ("Path is: " & myPath) End Sub
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
