Specifies whether the document contains any unsaved changes
TRUE: The document has no unsaved changes.
FALSE: The document has unsaved changes.
Syntax
Where:
BooleanVariable is a variable (True or False) specifying whether or not the document has any unsaved changes.
object is the Document object.
Examples...
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
