-Pan
Moves the entire drawing within the current viewport.
command bar:  -pan
transparent:  '-pan
shortcut:  PgUp, PgDn, Shift+Right, Shift+Left, Shift+Up, Shift+Down
aliases:  -p, pan, p
menu bar:  View | Pan
toolbar:  View | Zoom |
: -pan
Left/Right/Up/Down/PGLeft/PGRight/PGUp/PGDown/<Pan base point>: (Pick a point, or enter an option.)
Pan displacement point: (Pick another point.)
Pan base point
Specifies the pan distance's starting point.
Specifies the ending point.
Left
Pans the drawing 5% to the right.
The drawing is panned by 5% of the width of the current viewport.
Right
Pans the drawing 5% to the left.
Up
Pans the drawing 5% downwards.
Down
Pans the drawing 5% upwards.
PGLeft
Pans the drawing 100% to the right.
You can also press the Shift+Left cursor key.
The drawing is panned by the entire width of the current viewport.
PGRight
Pans the drawing 100% to the left.
You can also press the Shift+Right cursor key.
PGUp
Pans the drawing 100% upwards.
You can also press the Shift+Up cursor key.
PGDown
Pans the drawing 100% downwards.
You can also press the Shift+Down cursor key.
Pan moves the drawing within the current viewport.
RtPan - pan the drawing in realtime.
Zoom - increases and decreases the size of the drawing within the current viewport.
RtZoom - performs real-time zooming of the drawing.
