View
Creates and sets named views through the Drawing Explorer.
command bar:  view
alias:  ddview, v, expviews
menu bar:  Settings | Views
: view
Displays the Views section of the Drawing Explorer dialog box:
Create or select named views, and then click X.
Press F1 to access help.
Current
Designates the current view.
View Name
Specifies the name of the view.
Click to edit.
Height
Specifies the height of the view in current units.
Click to edit.
Width
Specifies the width of the view in current units.
Click to edit.
View Direction
Specifies the direction of the view in x,y,z coordinates.
Click to edit.
New
Creates new named views; clears the dialog box and then prompts you:
View: ? to list saved views/Save/Window - enter an option.
Lists the names of views saved in this drawing; prompts you:
View(s) to list <List all views> - enter a name or press Enter for all.
Bricscad reports like this:
            Name of view:  NewView1
                   Space:  Model
          Center of view:  X=   0.0000  Y=   0.0000
Press F2 to see the Prompt History window.
Save
Saves the current viewpoint as the named view.
Returns to the Drawing Explorer.
Window
Saves a windowed area as the view; prompts you:
First corner of view window - pick a point, or enter x,y coordinates.
Opposite corner - pick another point, or enter x,y coordinates.
Delete
Erases the named view from the drawing without warning.
-View - controls named views through the command bar.
Print - plots named views.
Rename - renames views through the Drawing Explorer.
Zoom - utilizes the Previous option to show the previous view.
