Adds or removes supported scales for annotative entities through a dialog box.
command bar: objectscale
properties bar: Annotative Scale
: objectscale
Select annotative entities: (Select entities)
Entities in set: 2
Adds annotation scales to the selected annotative entities. Displays a dialog box:
Select one or more scales in the list, then press the OK button to add the selected scales. Press and hold the Ctrl key to:
To select a series of scales: select the firs scale, then press and hold the Shift key and select the last scale.
Removes annotation scales from the selected annotative entities. Select the scale(s) to remove in the Entity Scale list, then press the Delete button. Press and hold the Ctrl key to:
It is not possible to delete all scales. If you select all scales, the Delete option is not available. Choose No in the Annotative field on the Properties Bar to remove the annotative property. |
The union of all scales for the selected entities are listed. |
Only scales that are shared by all selected entities are listed. |
-ObjectScale - adds or removes supported scales for annotative entities at the command line.
ScaleListEdit - edits the scale list of a drawing, used in Plot Scale section of the Print and Page Setup dialogs and the Standard scale property of a paper space viewport. Defines the available annotation scales for annotative entities.
