Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Controls the exporting of drawing in PDF format through the Settings dialog box.
command bar: pdfoptions
menu bar: File | PDF Export Options
: pdfoptions
Displays the PDF Export section of the Settings dialog box:
Choose options, and then click the X to exit the dialog box.
To export drawings in PDF format, use the Export command.
Determines whether TTF font files are embedded in the PDF file:
Determines whether TTF (true type fonts) are exported as geometry:
Determines whether SHX (shapes compiled) are exported as geometry:
Determines if the geometry is simplified to reduce file size:
Determines if the drawing is zoomed to extents:
Determines how layers are exported:
Determines which layouts to export:
Determines whether page size is specified:
Specifies the width of the page, in mm or inches. |
Specifies the height of the page, in mm or inches. |
Export - exports drawings in PDF format.
Plot and Print - export drawings to PDF files, if a PDF driver is installed on the computer.
