Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Records keystrokes to an SCR file for playback with the Script command (short for "record script").
command bar: recscript
menu bar: Tools | Record Script
toolbar: Tools | ![]()
: recscript
Specify a file name, and then click Save.
Enter drawing and editing commands, and pick points in the drawing.
When done, enter the StopScript command.
To playback scripts, use the Script command.
Specifies the name of the SCR script file. |
StopScript - stops recording the script, and saves it to an SCR file.
Script - loads and runs a SCR script file.
RScript - reruns the script.
Delay - pauses the execution of the script for the specified number of milliseconds.
Resume - resumes a stopped script.
