Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Loads and runs SCR script files through a dialog box.
command bar: script
transparent: 'script
alias: scr
menu bar: Tolls | Run Script
toolbar: Tools | ![]()
: script
Select an SCR file, and then click Open. The script begins running immediately.
To rerun the script, use the RScript command. For more information on writing scripts, see Customizing Bricscad.
Chooses the drive and folder name. |
Specifies the name of the SCR file. |
Opens the SCR file, and then runs the script. |
RecScript - records scripts to SCR files.
StopScript - stops recording the script, and saves it to an SCR file.
RScript - reruns the script.
Delay - pauses the execution of the script for the specified number of milliseconds.
Resume - resumes a stopped script.
