Creates a polar array.
Syntax
Where:
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
NumberOfObjects is the number of objects in the array;
IncludedAngle is the angle to fill in radians, with a positive value specifying counterclockwise rotation;
CenterPoint is a Variant (three-element array of doubles) specifying the center point of the polar array;
PointOnAxis is an optional Variant (three-element array of doubles) indicating the point on the axis of rotation.
RotateObjects is an optional Boolean variable indicating whether to rotate objects or not. The default is False (no rotation).
Examples...
