Class AcadDimStyle
Member of BricscadDb
The DimStyle object contains the settings that determine the appearance of a dimension. To access the DimeStyle object, use the following methods and properties:
| Methods | Properties |
| Delete | Application |
| GetExtensionDictionary | Document |
| GetXData | Handle |
| SetXData | HasExtensionDictionary |
| Name | |
| ObjectID | |
| ObjectName | |
| OwnerID | |
