Returns the extension dictionary associated with an object
Syntax
RetObject = object.GetExtensionDictionary
Where:
The object this method applies to;it can be one of the following:
All Drawing Objects, AttributeReference, Block, Dictionary, DimStyle, Group, Layer, Linetype, PlotConfigurations, RegisteredApplication, TextStyle, UCS, View, Viewport, Xrecord.
RetObject is Dictionary object
Examples...
GetExtensionDictionary method example
