Class AcadRegisteredApplication
Member of BricscadDb
An external application that has been added to the drawing. To register an application, add it to the RegisteredApplications collection object using the Add method. To edit or query a RegisteredApplication object, use the following methods and properties:
| Methods | Properties |
| Delete | Application |
| GetExtensionDictionary | Document |
| GetXData | Handle |
| SetXData | HasExtensionDictionary |
| Name | |
| ObjectID | |
| ObjectName | |
| OwnerID |
