Class AcadSelectionSet
Member of BricscadApp
The SelectionSet object represents one or more drawing entities which can be operated on as a single unit. To access the SelectionSet object, use the following methods and properties:
| Methods | Properties |
| AddItems | Application |
| Clear | Count |
| Copy | Name |
| Delete | Visible |
| Erase | |
| Highlight | |
| Item | |
| RemoveItems | |
| Select | |
| SelectAtPoint | |
| SelectByPolygon | |
| SelectOnScreen | |
| Update | |
| ScaleEntity |
